ARE ALL GN STARTER THE SAME
newhotair
JUST GOT MY MOTOR REDONE AND IT WONT TURN OVER RIGHT AND THE POS CABLE IS GETTING REAL HOT THE MOTOR WILL TURN WITH A SOCKET ,ITS A SG1 BLOCK THAT I PUT IN ANY HELP WILL DO
yes, they are the same.. how many different ways are you going to find to ask the same question?
have you checked the things that were mentioned in your other threads- grounds, connections, cable condition, etc?
Its hard to get answers on here you might get and answer and you might not so I hope you are not mad????
Go through each and everyone of these , found this on the net :p .
90% of starter problems are bad connections. remove and clean both ends of the battery cables, so that they are shiney, also the cable from the solenoid to starter. check for nicks in the cables. and make sure the connectors are on the wire good. the cable tend to corrode from the inside out, if nicked, corroded wires, and connections, heat up and cause resistance to the follow of electricity, thus the starter doesn't get enough. you can also take jumper cable pos battery post to large post on starter. with a good connection, the engine should spin. then if the starter is good clean everything and retest. then trouble shoot solenoid. starters can be rebuit at a starter/alternator shop, much cheaper than a new one.
also have the battery load tested at the
auto parts
store, free, i've had new batteries go bad.
I had a problem with mine, The rubber grommit had worn through and the metal had shorted itself out within itself..huge mess....Got a new starter and it worked fine.
