Mile Hi GN
- May 23, 2001
I know there is light years of technology between them, but pure dimensions.
Check me here:
PT-51 compressor 2.29" = 58 MM
PT-51 Turbine 2.795" = 70 MM
Using modern labeling, a PT-51 is a 5870. Smaller comressor diameter but larger turbine diameter than a 6262
Same drill - TE-44
TE-44 compressor 2.29" = 58mm
TE-44 Turbine 2.559" = 65mm
TE-44 = 5865
The point, if I'm spooling a 51 just fine, then the 6262 would not be too large for my high-altitude combination matched with a 9.5 NLU from Dusty.
Check me here:
Same drill - TE-44
TE-44 = 5865
