Anyone with a MAF translator
irockwithdirt
Senior Member
I picked up a LT1 MAF and translator from a LT1 guy, have the adapter plug from ramchargers. I think I need to change the dip switch settings (was for a LT1 V8- now going on my buick).
Anyone know where I can find this information?
TIA, Kevin
Try these setting to get started.
dip switchs - On,On,Off,Off
rotar switch - 3,3,0,0
I had the same set up do, except for stock injectors, and this worked well for me.
Once the settings are made drive around on the surface streets and do a lot of stop/go driving to re-set the computer (to let the computer learn)
Well somethings wrong. From reading the instructions I set the switches on, on ,on, off
And my rotary switches 3,0 (I only have 2.........not a trans +)
Car would start but not idle at all.
Guess my maf or my trans are bad. :(
Thanks.........I did try that setting today and no change.
Guess now I have to figure out if its the MAF or the translator :confused:
My friend just sold a LT1 firebird saturday or I'd swap it with his and see if the MAF worked.........day late I guess.
Lil bro has a late 90's chevy astro van with a vortec v6 in it........the MAF on it looks very similar. Does anyone know if by chance these are interchangable?
you need the 3 inch MAF from an lt1 B body i.e. impala ss, buick roadmaster 350, caprice, etc. the lt1 camaros/ta's use a 3.5 inch MAF. not sure about the astro MAF.
My wife has a 97 S-10 with a 4.3L. I have swapped MAF's with the one from her truck and it seems to work the same. However, both of the MAFs are 3".
