Originally posted by DonnieShort
I went from a pt52 to a pt61 P trim and it was even more of a difference. I ran my best times on this turbo through full ehaust and drag radials. 17psi on the 61 p trim felt like 26psi on the 52 Boy, I can't wait to feel the difference from the 61 to my new CPT70 P trim ( .82a/r )
Originally posted by c&cgn
Donnie, do you know specifically what exhaust wheel was in your turbo? I remember seeing your ad for that turbo and you said it had a larger wheel but I am curious to know which one.
It's kind of important to include that in a post like yours as alot of guys buy into the hype right away and buy a turbo that may not be right for them because they saw how much more power it made (on the internet).
Usually as PT61 is just a PT52 with the newer GT61 compressor wheel, which from the info I've seen is really not much better than a 52. Yours may have the turbine wheel that is the same as a PT54/TE61 or it's possible that it was one of the early ones that came with a P-trim turbine wheel which is equivalent to a TE62.
Just curious to know which one it is, which may explain why you feel it made so much more power.
Do you have any back to back timeslips with the 52 and 61 turbo's ?
BTW, I ran a 52 turbo for a year and a half and thought is was a very good turbo. Went best of 11.14 @ 120mph with it.
Thanks for clearing that up.
You did mention P-trim in the other post but did not mention the words "turbine wheel" with it so I guess I just did not notice it.
Basically, you went from a regular PT52 to a (what I consider) TE62 with the GT61 compressor wheel.
Who built your turbo? I don't think PTE is building them with the P-trim turbine wheel any longer.
PTE built it back in Aug. of 2004. It wasn't a month or 2 later that they went away from doing the P trim on it and doing just the 52 wheel for quicker spool up I was told. But it was labeled as a PT61 P trim, and for about 3 months it was all the rage almost fad-like. Then some concerns arose that it was so much like the 62 and we all remember the rap that it got. So between that and the slower spool up time with the P trim wheel, they went with the 52 only. At least that was explaination I got.
Originally posted by The Darkside
I had a TE44/.63 & had it sent to Limit Engineering/John Craig & he upgraded it to a GT61 w/ .63. He told me to just leave the 44 exhaust wheel in it. Does anyone else have this combo?
I know my car spools extrememly fast & I'm now fighting transitional knock w/ the alky. Car has actually broke the radial 245-50-16's loose from a 60 punch ...I really need some DR's...lol.
The Darkside
Originally posted by getchasum
Few questions for you.
Is the spool much slower than the 44 was?
What kind of turn around time did you have on the rebuild?
tks,
Hey Thomas, so you do have the same turbo as I have after all! I love it!Originally posted by d0n_3d
Yeah you have the same combo wheels as the other guy with the 6131. The TE44 turbo uses a T-31 exhaust wheel which is one size smaller than a T-350 wheel which is what we normally put in the PT61.
