Anybody use these before and did they work well? No pushrods in the kit either what size are you guys using?
Comp Part Number K69-200-8
Application Power Range Idle 800-5200
Quality/special requirements Valve Lift Int/Exh 496/496
Duration Adv.Int/Exh in degrees 258/258
Duration @ .050 Int/Exh in degrees 206/206
Lobe Centerline 110
Comp Cams hydraulic roller cam and hydraulic roller tappet lifter kit. Also includes springs, retainers, locks and double roller timing set, as well as cam break-in lube.
Lobe Centerline 110
