Yeah that's right... not sure why 2.25" came out of my keyboard yesterday.
It's an A-body with a 12 bolt, so it's not going to be as applicable to our stuff. However, there is a lesson learned out there about distance from back of rear housing flange to the LCA mount. The kit requires you to insert 2" long bolts from the back of the flange, so if you shorten the housing, you can't fit the bolts in there without interfering with the LCA mount.
My calipers were waiting for me when I arrived home from work yesterday, so I mocked the rear end up last night completely out of car.
With the calipers mounted, there is distance of 47-1/4" between them at their widest points, without bleeders installed. The bleeders are approximately 1/2" tall when installed. I measured frame rail to frame rail with help from the wife, and got a value of 47". Therefore, the bleeders are theoretically on an interference path. The Kore3 kit clocks the calipers lower than the LS1 backing plates do, so that will also help with frame clearance. Here's a picture of where the caliper sits relative to the axle tube.
I had to disassemble it to get some plating done and the housing painted, hopefully next weekend (the 13th), I can have it in the car to validate frame clearance when it's on the bump stops. I'm pretty confident it won't be an issue. In your case, if you bump the housing flanges out 0.25" and leave the axle flange width the same as stock G-body, you shouldn't have an issue, and the plus side is it should fit any G-body with standard wheel combination.
Hope that helps a bit. If I have some time today I may bolt up the LS1 brakes and calipers to judge the relative difference. Don't have a rotor though to make sure the caliper is center for the measurement.
