BlackMetal
- Sep 29, 2005
Engine is making noise and I'm not good at diagnosing. Noise is still there with the belt removed, I know that much at least. Still drives fine so I should be able to bring it to someone if need be.
You need to describe the noise, when it occurs, and general area you hear it. It could be your valve train (bad lifter, worn cam lobe, rockers, pushrods, etc.), could be your cam or crank sensor or it could be your headers.
Pretty sure I didn't lose any small parts while the covers were off, didn't notice any missing nuts or bolts.
Don't have an oil pressure gauge at the moment.
Where are you at?
