I have 120k mi on my '87 GN and am planning on changing the fluid and filter since I need to change my TCC solenoid switch due to an increase in RPM by 1 bar on the tach and back down while in OD the odd time. It's like I'm lightly touching my brake pedal with the gas pedal still on (TCC test). Is there anything else I need to change? I notice on the Monte site where they show this procedure to change the TCC SS that they also show the 4th gear pressure switch. Is there a test I can do to check to see if it needs to be changed or should I just change it?
