QwuickTurbo6
- Oct 11, 2007
I've been seeing some crazy fuel system problems lately. The car would lose fuel pressure and die while driving only to fire back up and run fine if I waited ten minutes or so. I ended up replacing the fuel pump and hotwire. Then I noticed my autometer gauge was showing zero psi as soon as I turned the car off, and it would take a few minutes to show 40 psi after the car was running. Ended up replacing the afpr and even the gas tank as the lining was coming off the tank and I thought it might clog the pump pick-up. Now my gauge shows zero psi while starting the car, doesnt respond quickly to boost, and shows zero after the car is off. It even starts gaining psi after the car has been off a while sometimes! The weird thing is the gauge worked perfect right before all these problems started. Do these things break or do I still have a problem like a leaking injector or something?
