Looking to add a compressor to the garage. The house is relatively new and has 220 for the AC already, the 220 ac breaker is in the top slot in the box with a few slots left above it. The box is on the outside wall of the garage directly opposite the spot (roughly) where I want to put the compressor. This spot already happens to have a 110 20amp single outlet there which is oddly placed only a couple feet from another regular 110 double outlet confused. I have no problem using the spot with the single 110/20a for the 220, so there's no hole or anything that needs to be cut.
Tell me if I understand the basics here: I need to put in a 220 breaker above the AC breaker. Run wire from that to the outlet in question, put in a 220 outlet? Seems like a half hour to an hour of work for someone who knows what they are doing. Am I missing something?
I feel like I must be because I called a couple of electricians and one of them said it would cost 400 dollars to do this, and the other said it would be 250. Are these insane prices or is that what I should expect?
