I finally have started tuning on the T-72'd SBC. I've got it going pretty good now. I just have a few idle/IAC questions. I've read all the previous posts about it and still don't really understand. My idle is higher than I've specified in the idle menu. I've specified about 900 and it's around 1100. At idle, my TPS is 18. So i set the max idle TPS to 19. I know i'm suppose to put the throttle follower all the way to the bottom (10) at my idle TPS percentage. Then adjust my throttle blades until i see 20-30 counts at the IAC TARGET. So i put the TF graph down to the lowest at 18% TPS (which is 10 counts) and that's what the IAC TARGET reads is 10. I tried opening the throttle blades up some but the target doesn't change. The only way I can get it to go up is by moving the throttle follower up a little (to 20-30). Should i CLOSE the throttle blades after i zero out the throttle follower? Will this make the target go up? Maybe I just answered my own question. I can't try it till tomorrow night so I'll go ahead and post this. I'll stop talking to myself now Thanks for any help!!!
