Analog Speedo Cluster (damaged/beat up)
87 WE2
I'm searching for a cheaper beat up/damaged cluster, does not matter if its column shift or not.
I need the guts to use the infrared eye function must have the screw in the back that holds the infrared eye in place. I will also take a known good VSS buffer as well if its available.
Price, shipped to 19014
Thanks - Ed
I have a bunch of VSS buffers, and I also have a standard gauge cluster. Can you use a standard one?
Unfortunately I have no idea I've never tinkered with an NA cluster to know if it still sends the 2x pulse signal the same as the turbo cluster nor do I know if the buffer is the same part number.
