AN Fittings/intercooler bracket/fuel filter bracket/fuel rail/motor fuel lines
TR Custom Parts
Mark Hueffman - Owner
30" teflon braided -6 hose with aluminum straight ends Endura finish - $30
-10 black pushloc fittings 2 45's and 1 straight - $5 each
-10 to 1/2" NPT straight adapters 2 black / 1 blue - $3 each
-10 to 1/2" NPT 45 degree adapter blue - $3
-10 rubber braided line straight hose ends, 2 blue/red and 1 black - $4 each
-10 straight o-ring to -10AN adapters - $5 each
-8 bulkhead fitting blue - $5
1/2"NPT to -8 black adapter - $3
-6 teflon braided line 45 degree steel fitting - $10 each, have 2
-6 teflon braided line straight steel fitting - $10 each, have 4
stock fuel filter bracket $5
passenger side stock location intercooler bracket - $15
fuel rail with injector harness - $75
motor fuel lines, supply & return, sold as a pair only - $100
-4 female to -4 male with 1/8" NPT port fitting - $8
3 steel fuel lines that attach to gas tank - $60
vacuum brakes check valve and filter - $15
All prices do NOT include shipping, Paypal accepted without any fees if you send as a gift! Let me know what you want out of these items and will put together a quote for you.
More pics
Do you have/ are these the fittings that replace the steel fuel lines from the frame to the fuel rail?
