Blown&Injected
- May 31, 2001
It seems to have been a long time since this issue has been discussed. I am thinking about going with -8 feed and -6 return. I currently have an internal pump and an external pump with -6 line going from the external pump to the stock filter, then stock stuff after but that stuff is rusted and leaking.
The reason I am looking at a different filter is that the -6 to O-ring adapter used to adapt the stock filter chokes the line down to less than 1/4" on the O-ring side!!!
I have read about cars running into the 9's with the stock fuel lines but if going with all new stuff, the volume from the 1/2 lines may just make it all work easier. Besides, I never liked the way the fuel line runs right up on the block and no more rust.
1) What AN adapter is needed on the fuel rail?
2) What adapter is needed on the fuel pressure regulator?
3) Any filter recommendations to get away from the adapter that chokes down to less than 1/4" on the feed side?
I do not have to keep the external pump if you guys have some better ideas - I have always wondered how effective it is to have two different pumps in line. maybe just weld a steel AN adapter to the steel line from the tank and bag the external pump? How fast are people going with just a single 340 in the tank?
