put 4 qts mobil 1 in the crankcase, pass side valvecover is off, trusty sbc oil pump priming tool is in, my drill only loads down *a little bit* the oil lite on the dash goes out, but theres barely a trickle of oil at a couple (not all) of the rockers... should i see a lot of oil up top or is it "primed enough"....i dont want to smoke the motor when i fire it back up
