Thank you John, and others.
This morning I got up went back outside to the garage and went over everything one more time. After reading a few other articles I became aware that there is a specific bulb that is supposed to go in the volt light terminal. (It provides different resistance, I guess). Mine was not in the correct place as a result of testing all the bulbs in the check engine light terminal last time I was out working in the car. (For future reference, the socket behind my dash that is supposed to be in the volt light position is black, and all the rest are gray. And if you look inside the bulb the volt bulb has blue on the inside.) So, after cleaning everything again, really making sure that the terminals on the harness were nice and flared, and putting everything back together I HAVE A VOLTAGE LIGHT!!!!!!!!!! Now that the problem has been diagnosed the field harness kit is the next thing to go on.
The only other thing I need to diagnose is why my dash turn signal lights do not go on. I have 1 small front lower marker light out. Once I get a bulb to replace it i hope it straightens out the inside issue. Turns out I had not 2, but 3 electrical problems at the same time. Thanks guys, Im glad the major issues have at least been taken care of.
