i know a bunch of you are running these spal fans they sell with the shroud that fills the area behind the radiator. Alradco comes with no set area to mount the relays. However i can safely fit and reach all connections if i tuck them inside the shroud between the radiator.
Im a little concerned with temps in there. Is this a completely terrible idea or could i get away with it? Only other area would be on the outside lower portion under the fans and i think i have to extend the wires.
