Dwilc47
- Jun 25, 2013
Fan won’t come on.
I recently removed the AC from the car installed a front mount at time also. Went for a 20min drive after I finished. Up pipe blew off the intake put that back on headed home. Saw my temp was 216 pulled over looked things over and saw my stock Fan resistor blew up and split In half.
I then installed the fbody radiator with intrepid fans Casper’s kit.
Was starting to flush the system, got it up to temp ran about 10 min then saw the fans were kicking on
Power to the stock relays. Casper relays have power also
Jumped the ac connector but fans didn’t turn on
Noticed the original fan connector has no power to it.
Fusible relay?
What’s the culprit?
Fusible relay?
What’s the culprit?
