T tonka Member Joined May 25, 2001 Jul 17, 2004 #1 Got to thinking about this, is a person better off not having the Power Plate installed in the plenum when using an alky spray? Wondering if anyone has tried back to back comparisons on this?
R Razor Forum tech Advisor Staff member Joined Jul 31, 2001 Jul 18, 2004 #2 Sure why not, your saturating air.. its being directed into your cylinders.. no problem. A lot of us run the PP and alky with no issue. HTH
T tonka Member Joined May 25, 2001 Jul 18, 2004 #3 So there shouldn't be any alky collecting or condensing on top of the plate as it is being sprayed....
R Razor Forum tech Advisor Staff member Joined Jul 31, 2001 Jul 18, 2004 #4 If you use water possibly. With straight alcohol..once it gets some hot air on it.. its gone. The plate will pickup oil residue from the PCV, doesnt seem that the alcohol washes it off. If that means anything.
