did some testing. first thing i did was drain all the race fuel out of my truck. then filled it up with 92 octane.
then i made a few runs with just the pump gas. the lowest boost i could run was 11psi and i had to put the timing all the way down to 13deg to get no KR. the gtech showed 520rwhp. IAT's starting at 72deg and going to 99deg in the 1/8th mile.
i didn't feel like messing around too much so i just turned the meth to MAX then started pulling fuel, it took a long time to get the fuel dialed back in. probably made 10+ 1/8th mile runs to get it where i wanted it. same 11psi, same 13deg and same no KR. the gtech showed 540rwhp. IAT's starting at 74deg and going to 77deg.
finialy i turned it up. i got up to 16psi and 17deg before i got any KR. i pulled it back to 16deg and kept it at 16psi and made a run. gtech showed a peak of 610rwhp but was mostly around 580rwhp. no KR. IAT's went from 70deg to 74deg .
then i did a full 1/4 mile run at this setting and it pulled a gtech corrected 11.1@124mph with a not so great 1.8 60'. IAT going from 71deg up to 75deg.
seems to work prety good but i am not going to say it works as good as race fuel. i was able to run 16psi and 19deg with about 105octane in there. last week at the track i was around 110 octane and ran a knock free 16psi+100shot at 16deg. i dont think i could do that with the alky and probably wont try. it does make for a prety stout street set up. i forgot to turn the speed based boost back on and hit it from a 20roll and it riped all 4 loose.
this truck is a durable. i put at least 20 1/8th mile runs on it tonight. i used up almost 1/2 tank of fuel . i do stuff like this all the time.
now.... that is my meth report. what is next? my turbo is maxed or i would play with more boost and timing settings. i have a pt88 going on in a week or two so i will have some room to play with that eventualy.
i am running razors kit with the 15 nozle. how much meth could i run and be sure of no puddleing in the intake? is there any reason not to run more meth and retune? i have a 4 gallon cell so running out is not much of a concern .
