blown okie
Chuck Norris Approved
- Apr 28, 2005
was driving the car today making sure everything is in order( at least as much as it ever is ) and enjoying the new trans.. and did a 65mph to about a 100+ mph blast and was running through the scanmaster readings (which i don't usually have the time to do just stayed glued on 02's and knock) and noticed that the ATS sensor just read HOT as apposed to a temp number as usual.. was amused by this.. rolled back through the scanner numbers on the decell from this blast and the first number that i saw was 126 degrees.. i thought wow!! anyways .. the ATS is in my up pipe as i think this is a more accurate spot to take the temp from and i realize im stuffing about 500 hp of air into a 400 hp intercooler and know this doesn't help things.. but at what temp does it start reading HOT instead of a temp number and i thought i remember hearing on here before that erics turbo tweak chips ignore ATS for tuning parameters is this true.. should i care.. combo is in sig. anything else ask.. TIA
