Doing a 200R4, air checking direct like the CK book states, piston wont stay applied like the others clutch packs do, it leaks down in aprox 1 sec, can see some slight bubbles from the small center piston seal, I have tried several seals, they are not damaged, direct drum looks great, the center seal in drum is left off for dual feed. Also, what is the part # of the inner piston seal, 8628246 ?, or 8628079 ?, I have tried both, they act the same.
This trans has never had a real great 2-3 shift, even dual fed.
Thanks for any input
Jim
Jim
