After making some upgrades the car cuts out and backfires @ WOT . However under normal driving and normal acceleration it does fine and spools fast. It just when you lay into it.
Set up
E 85
80b injectors
TA-49
Dirweks High Volume e 85 comptable fuel pump
Fuel Preasure set at 45 lbs
Wideband Gauge, knock, and boost
Hot Wire kit
140 amp
3 inch down pipe
new plugs and wires
Turbo Tweek Chip
LT1 MAF with translator
Cold Air Intake
RJR Powerplate
Ported Plemium and DogHosue
scan master
My readings are as follows
Engine off Cold Idle Warm Idle 15 min Drive
AF 04 14 09 06
L8 00 61 59 38
bae 11.7 14.2 13.9 14.0
Ine 128 128 112 112
bL 128 121 118 118
Mph 00 00 00 00
cle 60 101 171 167
AES 71 71 71 71
r 000 975 850 875
Eps .40 .42 .42 .42
IAC 140 29 02 01
cc 00 28,80,146 228 30,64,150,224 28,32,140,150,224,
( This number jumps from one to the next)
Nal 00 00 00 00
605 0.0 585 527
Set up
E 85
80b injectors
TA-49
Hot Wire kit
140 amp
3 inch down pipe
new plugs and wires
Turbo Tweek Chip
Cold Air Intake
RJR Powerplate
scan master
AF 04 14 09 06
L8 00 61 59 38
Ine 128 128 112 112
bL 128 121 118 118
Mph 00 00 00 00
cle 60 101 171 167
AES 71 71 71 71
r 000 975 850 875
Eps .40 .42 .42 .42
IAC 140 29 02 01
Nal 00 00 00 00
605 0.0 585 527
