six is enough
Tweaked has a new Home
- Dec 7, 2002
Iam using the Aeromotive fuel pump and have a question for those that also use this pump. My pump does not hold any pressure when the car is shut off. I was needing to know if this is normal for this pump as I changed the injectors on the car at the same time I changed the fuel pump. I have been having a popping in third gear now for a little while and trying to determine if it might be fuel related. Thanks for any help
