adjustable wastegate problems
Rigo's 87 GN
I recently purchased a pt-52 for my gn. I but and adj wastegate an I don't know how to set it up! How does it work with the wastegate solenoid?
Did you hook up your vacuum lines to the waste-gate and the solenoid ? If so that's all that's to it, to adjust the boost, make the threaded rod on the wastegate longer or shorter. I'm assuming you have a aftermarket boost gage, high performance fuel pump and a hot wire kit for the fuel pump, fuel pressure regulator, scanmaster, etc.
Check out this for more information on waste-gate plumbing http://www.gnttype.org/techarea/turbo/turbopage.html
Chuck
