It all started with my recent post on the Billet Servo that i had installed and was not too happy with . If you can find that post you can see what else I had done to the transmission . I was advised to get the X plate , which i did . I also got CK's heavy servo return spring . I drilled the feed holes in the X plate as advised . I had already blocked the line bias valve and put that spring in the accumulator valve . Just for the heck of it I took the sleeve and checkball out of the accumulator housing and blocked it . test drove it . light throttle shift into second felt like a slight bind up . shift into 3rd & 4th seemed ok . Didn't want to hurt it so I only went a little ways .
Transmission's on the bench again . . . Unblocked the line bias valve , used a heavier spring in it , unblocked the 1-2 accumulator housing put the sleeve and checkball back in it . The X plate and the old CH plate are the same hole for hole except the MTV hole and the lo/reverse feed hole . Like you , I don't see after comparing the two plates what differenc it would make . I thought I might have a checkball out of place when I put the Xplate in but they are right . I may put my 692 servo back in still using CK's heavy spring . Comments and help appreciated .
