Wow guys, im really shocked.... Too bad we didnt get that kind of praise when the thread was stickey?? LOL
Maybe i should forward some pictures to make that calendar for next year.
My car did make it up the ramp, but we werent going to try it with the GN, it sits lowwww.
That was my first time out taking pictures, not too shabby ehhh?
Here is the official list of whats done to the white car, the black one is faster.
Details of the run:
60' 1.624
330' 4.799
1/8 7.483
MPH 91.27
1000' 9.80
1/4 11.767
MPH 114.62 best mph 114.82
RACE WEIGHT: 3595 WITH ME
BLOCK: Stock 109 Motor never been out of car
HEADS: Stock 8445 never off
CAM: Stock
TRANSMISSION: Stock 2004R
TORQUE CONVERTER: Stock D5
DIFFERENTIAL: Stock 8.5 3:42 gears and stock axles
INTERCOOLER: Kenne bell
http://i103.photobucket.com/albums/m...n/100_0874.jpg
THROTTLE BODY: Stock, not even semi ported
RJC POWER PLATE: YYYYEEEEESSSSS!!!!
INJECTORS: Stock 90,000 originals
THERMOSTAT: ATR 160°
TURBOCHARGER: Stock 87 turbo regal, portmatched compressor housing to inlet bell
VALVE SPRINGS: Stock 90K originals
MAF: LS1 3.5 with Mark Hueffman cold air kit
DOWN PIPE: MPE Keith Mease 3" S.S. downpipe
EXHAUST: Nonexistant, just downpipe
FUEL PUMP: 340m with Kenne Bell hotwire relay
FUEL PRESSURE REGULATOR: Stock TTA 237, non adjustable
FUEL PRESSURE: 47psi
ALCHOHOL INJECTION: Yes, writeup about it here DIY- Junk drawer DIY kit, SMC controller, Sureflow pump,m-10, 1/8th ss line...
PROPAIN INJECTION: NO
NITROUS: NO
AIR FILTER AND AIR INTAKE: Mark Hueffman 4" to 3.5 at MAF
TIRE DESIGN, SIZE & AIR PRESSURE: M/T 28x9.0 ET drags at 12.0 psi cold
AIR BAG(s): 1 on pass side rear, 20psi
SUSPENSION: Missing front swaybar and endlinks, boxed rear uppers and lowers, air bag 20psi and ATR rear 1 3/8 sway bar
SCAN TOOL: Scanmaster 2.1
FUEL: Either 110 Turbo blue OR some type of Blue 112???
CHIP: TT Eric Marshall TT chip made at the nats for my grey car in 03?
CHIP TIMING: 27° in first and second 25° in third
KNOCK RETARD: .5 or 1.0 MAX entire run
OXYGEN SENSOR VOLTAGE: With SMC controller at 4, its 760's at 22-23psi
EXHAUST GAS TEMPERATURE: NO EGT
TRACK ELEVATION: LESS THAN 800 feet
TEMPERATURE: 55°
PEAK BOOST: 23
BOOST AT LAUNCH: 10psi foot brake
MILES ON THE CAR/ENGINE: 90,150 ish
