Gary Wells
White turbo Buick trailer park trash
- Mar 2, 2002
Parts for sale, no trades, cash only.
Home # (310) 537-2614 (preferred), cell (562) 618-9602
No pictures nor any shipping available.
’87 Turbo-T spare Parts list: GM Parts:
001: GM P/N 12353801, AC Delco P/N D552, NIB, Coil Pack, qty 2, $90 each.
002: GM P/N 18018141, AC Delco P/N 179-1237, NIB, switch, brake, kit, qty 2, $90 each.
003: GM P/N 18038507, AC Delco P/N 18M754, NIB, accumulator assy kit, qty 1, $200.
004: GM P/N 22525555, NIB, handle, shifter, burgundy, has buttons & chrome, $100.
005: GM P/N 24503624, AC Delco P/N D1996, NIB, Ignition Module, qty 2, $250 each.
006: GM P/N 25036663, AC Delco P/N 213-918, Throttle position sensors, NIB, 5qty 3, $40 each.
007: GM P/N 25516915, AC Delco P/N 213-143, Sensor, Camshaft, 2, NIB, $200 each
008: GM P/N 25518704, Cap assy, NIB, tri-shield insignia, 2 sets of 4 each set, $200 per set.
009: GM P/N 25519368, AC Delco P/N 214-609, NIB, Valve, asm, Fuel Pressure Reg,1, $150.
010: GM P/N 25523118, AC Delco P/N 15-5320, NIB, asm, valve, heater , qty 3, $40 each.
011: GM P/N 25525090, Bezel, R/H, NIB, USA made & plated, thick chrome plate, qty 2, $150 each
012: GM P/N 25525090, Bezel, R/H, & complete marker asm, driver quality, qty 1, $125 both.
013: GM P/N 25525091, Bezel, L/H, NIB, USA made & plated, thick chrome plate, qty 2, $150 each
014: GM P/N 25526387, Tensioner, drive belt, NIB, qty 3, $250 each.
015: GM P/N 25526613, ’87 Turbo-T chrome grill, NIB, $500.
016: GM P/N 25526984, AC Delco P/N 15-8230, NIB, Relay asm, fan, qty 1, $50.
017: GM P/N 20201221 weather-strip, L/H, NIB, $90.
018: GM P/N 25525381, trans mount cat hanger asm, rebuilt by m233roller. $90.
019: GM P/N 5936629, Lamp, Parking, GNX, export, clear lens, NIB, $100.
020: GM P/N 5936630, Lamp, Parking, GNX, export, clear lens, NIB, $100.
Aftermarket Parts:
001: Precision Turbo & Engineering (PT&E) 6262 DBB, “E” configured, NIB, $1600.
002: Napa Power-master P/N 390047: Master Cylinder, NIB, complete top to bottom, $900.
003: T/A Perf. Valve covers, wrinkle black, turbo 6 logo, NIB. Includes K&N 62-1040 breathers, $130
004: GM P/N (N/A), Garrett P/N 1011-144, NIB, waste-gate actuator, 21 PSIG, high boost, $85
005: GM P/N (N/A), Garrett P/N 1011-673, NIB, waste-gate actuator, 16 PSIG, std boost, $85
006: Denso P/N 234-1001, NIB, oxygen sensor.
007: Kirban P/N 7159, GNX center caps, NIB, 1 set (4), $80.
008: Kirban P/N 102063, NIB, Headlight brightener, $40
009: Kirban P/N 6700, stock steel hood gas shocks. $40.
010: Kirban P/N 6796, vacuum block, 5 port. Qty 2, $35 each.
011: Kirban P/N 7433, antenna repair kit, $35.
012: Kirban P/N KE003, re-gasket A/C Delco radiator cap, $20.
013: Autometer P/N 4303 vacuum-boost gage, NIB, silver face.
014: Energy Suspension P/N 9.6101R coil spring isolator, NIB.
Parts from my car @ 18K miles:
001: Mike’s (SPOOLFOOL2’s) Kool Kustom turbo cover, $200.
002: Stock ’86-’87 turbo Buick turbo cover. Off my ’87 Turbo-T, almost as new, $70.
003: Stock intercooler, $100.
004 Stock valve covers, $25.
005: Stock dog house, $25.
006 Stock starter, working when removed, $40.
007: Stock FPR, $40.
008: Stock ignition module, worked when removed, $100.
009: Stock coil pack, worked when removed, $40
010: Stock spark plug wires, worked when removed, $25.
011: Stock intake system, $100.
012: stock up pipes (2), $25 each.
013: Stock alternator, 2, 1 worked when taken off, 1 needs rebuilding, $ 50 for both.
Aftermarket Parts:
