gnpoweredrail
- Mar 22, 2010
so check out my bad luck...
One of My heads actually had a crack inbetween the valve springs so I took a set of 30,000 mile virgin ones to redo and put my big valves in...get them back and installed,torqued and retorqued and found out my rockers wont fit as the pedastals have to be machined like my old heads!!! damn this sucks..another set of gaskets down the drain.
what is weird is i could only get 58-64 ft lbs when I loosened the nuts????? maybe because the moly wasnt burned off yet???
Anyone ever pulled heads without running them and see a lesser torque then what you torqued them to???
Am I just being paranoid? also I unscewed the studs so I could reseal them again.
Do I wait for the silicone to dry before I install and torque the heads or do it imediately.
