When I'm WOT running in 3rd gear, I'm getting a sound from under the hood like a popcorn machine, or a bunch of pi$$ed off bumble bees in a jar. It's not registering as knock, and the car pulls hard right thru it.. but what that hell is it???????? Showed up all of a sudden. Here's what I've tried so far.
New plugs gapped at 32, wires, swapped coil pack. (not ignitiion module, but that might be next)
Checked all couplers numerous times.
Pulled cleaned and re-attatched positive battery cable and negative gounds.
Raised and lowered boost 18-22 psi
Pulled 2 degrees timing (21-19)
Fuel adjustments all over the board.
Even swapped turbos.
I'm running out of ideas, and would like a few new ones!!!!!!!!
