The compressor needs to be removed and make sure no old oil is in it. Pour half into the accumulator (port does not matter, oil circulates through the entire system), half into the compressor. Change out all the o-rings, put it all back together, pull a vacuum for about 30 mins and shut the pump down. Take the reading and walk away. Check it again an hour later if the reading is the same, turn pump back on and come back next day (really a few hours is sufficient, but better safe than sorry). Remove pump, charge and enjoy.
