JamesDean305
- Dec 14, 2010
Please help!! I recently bought an 86 g.n! The car was not running when i had bought it. The car had been sitting for quite some time. When the car is started it sounds like it is missing rlly bad and wont stay running unless i give it gas. I have replaced the coil, module, plugs (ngk 2771), wires (accel 8.5), fuel injectors (60 lbs), w/ matching chip, fuel pump(Walbro 255), crank sensor, and cam sensor When i got the car the trunk was filled full of misalliances parts. So, the cam sensor i used was on that was in the trunk. I had bought the cam sensor setting tool and followed the direction to the tee when installing. I believe it was installed correctly. Yesterday i did a compression test a found some strange readings.. cyl 1 had 55 psi, cyl 2 had 55 psi, cyl 3 had 60 psi, cyl 2 had 55 psi, cyl 4 had 50 psi, and cly 6 had 60 psi! cyl 1,5,2 and 6 where fouled out just after a cppl time starting, and cly 3 and 4 where good just with what seamed a lot of gas on them when pulled. Blown Head Gasket? Bad cam sensor??
