95TAMaddog
- Jul 1, 2006
1988 LX Mustang. Black with Red Interior.
This car is very streetable. It's a pump gas 306, The engine has a Saleen intake, 24# injectors, Cobra mass air meter, 70mm BBK throttle body, Eldebrock Aluminum Performer 5.0 heads with light amount of port work, Lock wire head gaskets, Roller rockers, Lunati Hydraulic roller camshaft 230/240 @.05 with around .520 lift,Light weight TRW pistons, Stock block, Crank and rods, Mac long tube headers. NOS dry kit. Can get around 15mpg if taken it easy on it.
Trans: Tremec 3550, Lakewood bellhousing, Spec Aluminum flywheel, Spec stage 3 clutch, Hpm Cross member, Aluminum drive shaft.
Rear Axle: 8.8 with 31 spline Moser axles, 31 spline limited slip, 3.73 ring and pinion.
Suspension:Front- UPR tubular K-member, UPR tubular A-arms, UPR caster camber plates, UPR coil over kit, Lakewood 90/10 struts.QA1 coil springs.
Suspension:Rear- Hpm Mega bite JR. lower control arms, Eldebrock double adjustable uper control arms, Lakewood rear shocks, Hpm sub frame connectors, CCM Fabricated 3/16" steel Torque boxes.
This car has much more , I have over $13,000 invested.
$7000 obo
Hughey Bellue
$7000 obo
Hughey Bellue
