87 T-type nightmare (dont look if your sqeaamish)
Sorry man just seen this post I could have maybe helped. At least got u some good paint supplies.
Tomorrow is the big day yay
It looks as if you are doing it right to me.
Then again, I don't know jack.
If u need it cut and buffed let me no and I can help ya if u want to come up
Heh, not yet. I haven't checked into how yet
Sent from my SAMSUNG-SGH-I727 using TurboBuick Mobile mobile app
Appreciate it. And don't worry. Fixing the safety switch is priority one. Car has been in the shop, so I haven't been able to look at the switch. It scares the hell out of me every time I crank it. I triple check the shifter every time.
As far as the switch goes... the ring around the base of the column... it turns by hand, and engages the safety switch. But moving the shifter did not turn the ring. What is supposed to be in there to make that happen? I hope that makes sense
Appreciate it. And don't worry. Fixing the safety switch is priority one. Car has been in the shop, so I haven't been able to look at the switch. It scares the hell out of me every time I crank it. I triple check the shifter, make sure the e-brake is on and put my foot on the brakes every time.
Sorry had to fix that for you. :D
BTW its more like priority #5 or #6:cool::D
A rod connected from the trans shift bracket to the steering column, that rod also looks the shifter when the ignition key is not in its place.
I bet that rod is missing. I'll have to check that after work. Thanks
could just be disconnected i think its held in place by a washer and cotter pin, i also think that the shift bracket has two plastic inserts/bushings to smooth things out.
I sure hope so. Still have lots of cleaning to do first.
Just wait I am going to give some a good beat down!!! Maybe??
I'm just going I can beat a 10 flat. Look out 4 cylinders
U can go low to mid 8s with tires and a little tlc
Well the Buick is back at home. Paint turned out pretty good. Should be perfect after it cures and gets a good buff. I'm tickled for it to be drivable again.
Total price with parts and labor:
Under $1500. And more than one 12 pack:)
