87 intake coolant lines diagrams
crashedout1
Does anyone have any good photos or a diagram of the cooling hose routing from the intake manifold on the 87 this is going on my hot air but I've never owned I 87 but I'm putting this intake on my hot air engine need to know the coolant hose routing etc
Does you donor engine have the twin solid lines that run down the PS of the engine?
If so you need three 90's where they meets the heater. Up front you need a hose with 2 90's, and a very hard to find S-hose that goes from the intake to the timing cover. (I have those if you need one).
I did not re install the throttle body lines and the heater valve is a aftermarket one I believe.
And where does the one on the passenger's side next to the injector go its got threads on it i can't tell in the photo?
One with the threads goes to a nipple on the intake. The one below the thermostat is the S hose goes from the intake to the back of the water pump. Kirbans sells the S hose, that's where I got that one. Zoom in.
