1987 GN just about 38,000 original miles. Mint,mint in and out. Cold A/C tilt cruise control, eaton posi.
Performance: Te45a turbo q-trim,billet caps and balanced 235Ci (TRW's), ported-polished heads with 1.77i and 1.55e manley stainless valves,Harland Sharp rockers,comp cam 212-206,Quad ait xp fuel pump, adj. fuel pressure reg.,hot wire kit,Accel volt booster,CAS v4 interecooler (27row),Jet hot exhaust 2 1/2" ATR Manderel Bent, 3" stainless THDP,62mm Jay Jackson Throttle body, 55lbs. injectors with Mod ECM, turbo tweak chips (race/street),turbo 400 trans. with manual valve body, percision 3400 stall convertor, B and M trans cooler, trans + and Ls1 MAF,auto meter boost and tach,dual electric fans, Comp. engineering adjustable upper and lower control arms, ATR sway bar, boost controller, drive shaft loop,mini starter,direct scan,ect.ect.
$18,500 photo's available on request. documents/receipts for everything.
tgamino@yahoo.com 1-734-693-1692 SE Michigan
