Pampered 42K mile car that is beautiful inside, outside, and underneath. Thousands worth of sensible bolt-on upgrades for moderate performance and handling improvement. All 100% reversible to stock equipment, and parts to do so are included. Updates include:
- Fresh TE44 turbo
- Terry Houston downpipe, test pipe with capped side exit
- Big Mouth cold air intake system with 9” K&N filter
- “009” injectors
- Analog vacuum/boost gauge (with replacement A-pillar trim, have original with no holes)
- Manual boost controller
- Duttweiler modified stock intercooler (I have the untouched original)
- Full body and frame brace kits
- All new body mount bushings including GNX only center rubber component, and large pinion snubber
- Scanmaster diagnostic system
- GNX style 16” wheels with custom chrome Buick center caps (again, I have original 15” wheels in excellent condition, with 3000 miles on tires)
- Eibach Pro-Kit performance suspension lowers car about one inch.
- LT1 valve springs
- Casper’s fuel pump hot wire kit, Wilboro 340 pump
- PTE transmission shift kit
- Bosch fuel pressure regulator
- 2.5” Dynomax exhaust including mufflers
- R134a conversion for A/C
- 160 degree thermostat
- RJC power plate
- Much more….
- All mods done one step at a time, by a knowledgeable adult enthusiast, car never abused and meticulously maintained. The list goes on…all records, receipts included.
This is a very nicely optioned car with all power accessories plus the Concert Sound II (6-speaker) stereo system that still sounds great (very rare). Other key options include, but not limited to:
- C49, Rear defogger
- D68, Remote mirrors
- A01, Tinted glass
- G80, GU6, Posi-traction with 3.42 gears (this was NOT standard)
- TT5, T63, Halogen lights with warning chime
- N33, Tilt wheel
- CD4, Wiper delay
- K34, Cruise control
- US7, Power antenna (still works with radio on/off switch!)
- A90, Power trunk release
- WG1, 6-way power seat
- A31, Power windows
- AU3, Power door locks
- FE3, Sport suspension
- K09, 120A generator
Everything works, heat is hot, A/C is cold, tires are like new…..needs nothing. Email pab1063@new.rr.com or call 920-205-1295. Price is less than build price at $25,000 (receipts approach $30K), for a fully sorted car with all original parts included. You’d easily be money ahead if you want to put the car back to stock and sell all the go-fast goodies. After all that work, I just can’t bring myself to do it.
Only thing changed since the pictures were taken is that the valve covers were removed and professionally polished, then Zoop sealed. They're beautiful.
- Fresh TE44 turbo
- “009” injectors
- LT1 valve springs
- RJC power plate
- Much more….
- A01, Tinted glass
- N33, Tilt wheel
- CD4, Wiper delay
