86 gn
hardtop
new shortblock
eagle h-beam rods
eagle forged crank
arp rod bolts
arp main studs
t/a billet main caps
cometic .040 head gaskets
je pistons .030 over
je rings
clevite bearings
internally balanced
new harmonic balancer sfi approved
new flywheel sfi approved
champion cast iron ported heads
42lb injectors
accufab fuel pressure regulator
te60 turbo
3 inch downpipe
precision intercooler
polished rjc pulleys
brian hofer built transmission
pats 3200 stall
new carpet
new seat upholstery
new weatherstripping
new molding
ta 270 cam-270 duration .455 lift
t/a performance lifters
new ta blueprinted oil pump assembly.
slp zr1 rims
drag radials
also has hoosier slicks, mounted on black steel rims
new gm radiaitor
new gm emblems
i am sure there is something i am forgetting, so dont hesitate to ask.
outside is a 9.5 out of 10 i have pics of the paint process
all new weatherstripping and molding
inside is a 9.5 out of 10
i am asking 15500.00 for the car. the engine is brand new. it has approx. 300 miles on it. the old engine and heads come w/ the car also. it also is a 109 block
i had this car knocked down to 14k, but i have continued to spend money on it. so that is why it is listed higher now. so make some offers. NO BIKES. NO JUNK.
not wanting to trade up unless on a c5
car is in georgia
car did run a 7.91 1/8 at only 13lbs of boost. only chip i have, plus i was trying to take it easy on the motor.
i can email more pics
hardtop
new shortblock
eagle h-beam rods
eagle forged crank
arp rod bolts
arp main studs
je rings
clevite bearings
internally balanced
42lb injectors
te60 turbo
3 inch downpipe
pats 3200 stall
new carpet
new seat upholstery
new molding
slp zr1 rims
drag radials
new gm radiaitor
new gm emblems
car is in georgia
