Simple math
Here's the math needed to figure the injector size vs the HP..
Estimated HP X BSFC
________________ = Inj size in #/hr
# of inj's X duty cycle
Bsfc = Brake specific fuel consumption. [#'s of fuel per HP, per hour]
A general value is .45 to .50 for N/A engines.. Depending on efficiency of the engine...
A value of .60 to .62 is used for forced induction engines.
A duty cycle can be from 80 to 100%... 85% is pretty common, so the injectors don't get hot and go whacko...
Here it is done w/ your info:
850 X .6 510
----------- ----- = 100 PPH injectors.
6 X .85 5.1
Turn them on 90%, and the required size is 94.4 PPH.
Given the short duration of WFO operation, I'd go w/ 95's...
BTW, I have about the same engine combo you are talking about. I use the 95's....
