As some of you know I just got my 82 GN from 82grandbeast in Fort Worth. She's home now and after a couple of days I finally got out in the heat to get a better look at her and it doesn't look to bad. I'm sorry guys but it won't be a true restoration it's going to be a resto-mod car. She started life with a 4.1 in her and it may go back in but for now it will be a 3.8 carb/turbo set up I have been working on.
I already have my plan in mind so don't try to talk me out of it, it won't work. I have a complete 83 T Type that was going to take a lot of work to make it drivable so it's now my parts car. After I get what I need of the 83 parts will be sold off to help with expenses as well as get some more parts out there for the rest of you so you can put what you need for your toys.
The plan as it stands is the frame of the 83 will go under the 82 so I have the 2004r as well as the 3.42 posi rear. Granted it's a 7.5" rear but for now it's enough. I do have an A body rear that might go under her later but the main point is to get as much together as quickly as possilbe. Since the 82 has t tops I will be boxing the frame for more stregnth so the chasis flex is less. It will only qualify for bracket racing instead of a "stock" class but as it stands there is no calss the car can run in right now.
The rebuilt engine will be torn down this week so I can see if the rebuilder did it right or not. From what I've seen so far it looks good but I haven't taken it apart yet so we'll see. The cam I've chosen is a 204/214 grind and I have brand new KB 1.6 rockers as well. I've got 1 good turbo, 1 that needs rebuilding, and 1 that I'm modding for better boost. I'll start with the stock one for now so I have a better idea of what mods I'll have to do when I put the bigger one on.:biggrin:
Here's some of the pics I have so far. She is better than I thought since it has the dreaded t tops. I haven't taken the frame out to check underneith but I put my fingers up in some of the holes to see how it feels and there's very little damage, but I'll know for sure when the brace comes out.There is some rust holes in the passenger floorboard but none of them are any bigger than the eraser on a pencle. compaired to the 83 I have a LOT less work to do, thank God. :biggrin:
