We Just Built This Car And Are Looking To Sell It For Less Money Then Is Invested Into The Motor!
Here Is The Loooooong List Of Upgrades,
Pt67 Turbo 755hp
CAGED
Atr Stainless 3" Downpipe W/ 3" Racepipe
Deke High Impedence 60lb Inj.
Street Chip 60lb Inj By Turbo
Complete 2 3/4" Aluminized C/b Exhaust System 3" Race Magnum
Double Rolling Timing Chain
Quad Air Double Pumper Fuel Pump
Turbo Saver
Pts Extreme Billet 9x11
Gn 14 Bolt Stage Ii Full Race Port Includes Scorpion 1.65 R.r.
Comp 212/212 Flat Tappet Camshaft Duration260/260 212/212 @ .050 112 Degree Lope Sep.
Gm Lifters
Pushrod Gn 8.90
High-volume Oil Pump Front Cover
Steel Main Caps
Piston +20 3.8 Std Trw Forged Pistons
Ring Sets Std +30 Soeed Pro Ductile
Buick V6 Rod Bolts 1.700" U.h.l.
12 Pt Head Bolt Kit
Main Stud Kit
Big Rear Wheel Cylinders
Water Pump After Market
Champion Intake Manifold Cnc Ported Lower
Polished 90mm Plenum
Aluminum 3" Mass Air Flow Pipe
Metco Therm Housing
Aluminum Crankshaft Pulley, Black Or Polished
Clevite Bearings
Line Lock
Adj Proportioning Valve
Metco Lower Control Arms
Air Lift Bags
Buick Maf Translator Plus
Caspers Hot Wire Kit
Knock Detector
Atr Adj Billet Fuel Reg.
Scanmaster Diag. Tool
Double Full Pod
8.5mm Msd Ignition Wires
Turbo Regal Driveshaft Safety Loop
Metco Upper Control Arms
Rjc Power Plate
63mm Throttle Body
Ls1 Mass Air Flow Sensor 3.5"
Mass Air Flow Sensor Lt1 3"
Aluminum 4" Mass Air Flow Pipe
Tcc Lockup Soleniod
Fan Hi Low
Diagnose/ Fix Stock Computer
Cometic H1602060s Buick Multilayer Steel Shim Head Gaskets
Oil Pan Gasket(cork)
Fel-pro Intake Gasket
Timing Cover Gasket Set
Manual Adj. Boost
Tweaked Ecm Chip(custom Race)
Serpentine Belt
Phantom Boost Vac Gauge
Delco Brake Switch
Oem Replacement Radiator
K&n 8" Filter
Iac Angle Boss 90 Degree Adapter Plate
4" Mass Air Pipe
Well I Think Thats About It Besides All The Little Gaskets And Grommets And All That. Just Give Us A Call 770-443-7494
Pt67 Turbo 755hp
CAGED
Turbo Saver
Gm Lifters
Pushrod Gn 8.90
Steel Main Caps
12 Pt Head Bolt Kit
Main Stud Kit
Metco Therm Housing
Clevite Bearings
Line Lock
Air Lift Bags
Knock Detector
Double Full Pod
Rjc Power Plate
63mm Throttle Body
Tcc Lockup Soleniod
Fan Hi Low
Manual Adj. Boost
Serpentine Belt
Delco Brake Switch
K&n 8" Filter
4" Mass Air Pipe
