My old 85 setup turned 112-113mph in the 1/4 at 17psi on 91 octane gas. That is over 400 HP I belive.
It had a TA-54 with .85 housing, modified stock IC, 55# injectors, stock heads, 3500 stall 9" non-lockup, etc. Enough parts to run high 10's at full tilt. In vegas it ran 117mph at 21psi. Everyone from around here was running 3-4mph off their normal mph.
i'm working on getting the bugs worked out of the new setup but it went 92mph in the 1/8 at 17psi already.
