I found a guy with the new M/T drag radials in stock. I'm just wondering if anyone is running a 295/65/15 tire without rolling the lip. I have 15x10 Weld draglites right now with nitto 275/60/15's that don't rub at all. Also have airbags on both sides.
IF the 275/60/15 is around 28inches in diameter, so the 295/65/15 is going to be close to 29.5 inches. I would think that would be pretty tough to fit in. If it was 295/55/15 it might work as the diameter would be just under 28 inches
The section width is the killer here......the MT's section width is advertised as 12.4" I run Goodyear slicks (29x10) and they have the same section width. I use a 10" rim with the slicks and they BARELY fit and my framerails are notched and the fender lip rolled....Good luck
