Here’s the deal. I am building a new engine for my 87 GN and I’m using cast iron ported heads with a roller cam that has a lift of .507 (at the valve), hydraulic roller lifters and roller rockers. I decided to use comp cams beehive springs part number 26918. The spec sheet calls for an installed spring height of 1.800 which would yield a seat pressure of 130 lbs, or an installed height of 1.750 yielding a seat pressure of 146 lbs. The LC3 engines have an installed spring height of 1.727 (mine varied from 1.630 to 1.672) So if I go with the 1.750 height, this means that I need to cut the valve spring seats a maximum of .120 (1.750 minus 1.630).
I had an old scrap head laying around so I decided to drill the valve spring seat area and see how much material there was in this area. I found out that there was only about .210 of material until I ran into the water jacket, keeping this in mind if I had the spring seats milled down .120 this would leave me only about .090 of material!!! Way to thin for this much spring pressure. So my question is this. What do the guys do who run these springs? Or possibly I made a mistake in choosing these springs – these are the ones Comp Cam suggested. Any words of wisdom for me?
Mark
Mark
