elcamino383
- Jun 12, 2004
trans has been awesome till today. its a Bow Tie Overdrives Level 3 with about 1500 miles on it. i did a WOT blast with drag radials and hooked good, immediatly after it would not shift at wot, only when you let off would it shift to the next gear. at light throddle it would drive normally. than soon after (on way home) i was crusing 55 in 3rd and all the sudden it was in neutral. i lost everything, all gears are neutral. there was no noise of any kind. fluid is full and red, trans is 150-180 degress and tv cable is fine. checked with gauge and all readings are ZERO. is the pump gone? what else could i have damaged.. any tips on pump replacement? where is it located. thank you.
