2004r TV Valve stuck
DaveD
Looks like I will have to pull my valve body to un-stick my tv valve, anyway to fix this from happening again?
Before tearing it apart disconnect the tv cable from the throttle lever. Pull the cable all the way out then let go of it and let it snap back. Do it a few times. It worked once on a 700r4 for me.
You can put a helper spring behind it to return. Call Lonnie at Extreme Automatics he can fix you up
