elcamino383
- Jun 12, 2004
my BTO level 3 took a crap a couple months ago. chris @ CK sent me a new band and some new frictions and steels. i was scared to install them so i took it to a local trans shop. they said the trans was never built correctly in the first place because something was dragging and not releasing properly i donno exactly. but they installed the parts chris sent me, along with a new direct clutch drum, that was badly scortched. well here is the problem..
normal slow acceleration the car will NOT upshift to any gear without lifting throddle, than it snaps and shifts quickly.
under WOT accel the car will NOT shift 1-2 unless i lift. (went to 7100 rpm) but 2-3 it shifts right at 6500 under WOT, exactaly where i want it.
also there does not seem to be compression braking in any gear.
so the question is, is this all governor related? how do i get my 1-2 shift back at WOT and my low rpm shifting back too. Thanks a lot
