Three passes
9.123@76.80;8.751@79.51;8.848@78.70
60ft times respectively 2.194,2.002,2.015
ALL RUNS ON CA 91OCTANE PUMP GAS ONLY
I have the last two runs recorded on DS files if you would like to see I could email it to you.
Mods are only bolt ons
Turbonetics T62 Turbo and 42.5lb injectors set at 45psi at idle
ls1 3.5" translator plus and extender chip
Pat's 10" 3400stall converter brake stalls at 3100 at the line
Boost was too high in first run (16-18lb), turn in down to an unknown about of boost(maybe 12-14lb)after first run
The first 4 seconds of the last two runs apparently looks decent; however the last 4 seconds and some change the CAR FALLS APART! KNOCK retard consistently at 7-10* in THIRD GEAR ESPECIALLY. First to second looks good however.
Any help would be appreciated, first time to track with this car.
