Posting for a friend, please use contact info below. Vehicle is located in AZ
1989 GTA Trans Am Roller, Chromoly tig welded 8.50 cage, swing out door bars, very nice, needs recerted, Currie 9 inch with anti-roll, Strange center section, subframe connectors, BMR Drag Pak torque arm, QA1 12 way adjustable shocks in rear, and Lakewood struts up front. PA tubular k-member, coil over kit. Convo Pros and new tires. Perfect Factory dash, and headliner, clean stock interior except for Kirkey seats, and B&M shifter. Has window net, and removable parachute mount. rear mount battery, with switch. Body is clean no rust Arizona car. Good original paint, and cowl hood. (No motor, trans, ignition, or exhaust). $5500 E-mail chargedvet@q.com for pics. I have a Small block rotating assy and turbo kit that can go with car for additional.
