chmirror87
- Oct 30, 2009
1987 BUICK TURBO-T, FACTORY 3.8 SFI TURBO INTERCOOLED
240,000 MILES
************FACTORY OPTIONS************
POWER LOCK, WINDOWS AND SEAT
RARE POWER SPLIT BENCH SEAT WITH COLUM SHIFT BLUE INTERIOR
DIGITAL DASH
CRUISE CONTROL
TILT WHEEL
ICE COLD AC R134A
6 SPEAKER CONCERT SOUND- CD PLAYER AFTERMARKET
REAR DEFOG
WO2 BLACKOUT TRIM PACKAGE W/VERY RARE CHOME MIRRORS
****************MOTOR*****************
THE MOTOR HAS STOCK CAM, STOCK HEADS, COMP 980'S VALVE SPRINGS.
REPLACEMENT OIL PUMP WITH A THRUST PLATE, DOUBLE ROLLLER TIMING CHAIN.
************MODIFICATIONS************
CASPER ELECTRONIS ALTENATOR FIELD FIX MOTOR HAS 30000 MILES BUILT BY D&S PERF. ASSEMBLED &INSTALLED BY BUICK TURBO PERF.
TE 60 TURBO W/ FENDER DUMP
009 42.5# INJECTORS W/QUAD AIR 93 CT. STREEP CHIP
ADJUSTABLE FUEL PRESSURE REGULATOR
QUAD AIR XP PLUS FUEL PUMP-MOD. WALBRO 340
CASPERS ELECTRONICS FUEL PUMP HOTWIRE KIT
RJC POWER PLATE
10MM MAGNECOR INGNITION WIRES
ALUMINUM MAF PIPE W/K&N 9IN FILTER
K&N VALVE COVER BREATHERS
ENGINE TORQUE STRAP
H.D 3 CORE CAS RADIATOR
CHOME IC UP PIPE
COOLING FAN WIRED FOR HIGH SPEED
160* THEMOSTAT
BILLET ALUMINUM VACUM BLOCK
HI TORQUE MINI STARTER
H.D IC HOSES
DOUBLE ROLLER TIMING CHAIN
OIL PUMP MODS
LT1 VALVE SPRINGS
AFTER MARKET PILAR MOUNT-OIL PRES. & BOOST GAUGE
***************TRANSMISSION******************
50,000 MILES ON REBUILD
ART CARR SHIFT KIT
LESTER 134 SOLID SERVO
PPC 12” LOCK UP 2,800 STALL TORQUE CONVERTER
B&M TRANSMISSION COOLER
***************REAR SUSP. & EXHAUST***********
AIR LIFT AIR BAGS
ATR 3” STAINLESS STEAL PITBULL EXHAUST W/3” DUMP TUBE
REAR BILSTIEN ADJ. SHOOKS
HAVE STOCK RIMS
I am asking $5,000
My email is jody.davis.tech@gmail.com
Phone is (315) 246-2469
Located in Genoa, New York
240,000 MILES
DIGITAL DASH
CRUISE CONTROL
TILT WHEEL
ICE COLD AC R134A
REAR DEFOG
RJC POWER PLATE
ENGINE TORQUE STRAP
CHOME IC UP PIPE
160* THEMOSTAT
H.D IC HOSES
OIL PUMP MODS
LT1 VALVE SPRINGS
ART CARR SHIFT KIT
AIR LIFT AIR BAGS
HAVE STOCK RIMS
I am asking $5,000
